Im playing around with adding a probe and using some of the probing functions in mach 3. I have a 1/2 dowel set as tool 99 and it works fine for touching off the surface when used with the avid touch plate. All of the other probing functions will not work though when there is a height offset applied to the tool. It starts moving but then it freezes. I can zero out the tool offset and probing works, but then I cant use it to touch off the surface of anything, all the tools in my atc with be incorrect. Any thoughts?
Related topics
| Topic | Replies | Views | Activity | |
Automatic Tool Height Setup Question
29 | 1443 | November 4, 2022 | |
Mach3 touch probe
7 | 1505 | March 19, 2023 | |
Has anyone used a surface probe with Mach 4
12 | 1253 | December 25, 2022 | |
| Touch probe in Avid CRP800 control | 41 | 2058 | July 8, 2024 | |
Avid Touch Plate bug when a tool height is set and active
29 | 872 | March 12, 2023 |
