Relay options on EX Contoller?
Hey all, looking at a purchase of a Pro4896, what are the available relays on the controller for running coolant / red dot? I’m not finding much on the site besides their power relay box, but have to assume a modern controller has available assignable relays, right?
Thanks all
-Doug
Those relays can run 110 and 220 accessories, so if you have a pump that runs on that voltage you’re good to go.
Those external relays are run by two opto-isolated dry contact relays that are in the control box. They are accessible and could be used if you didn’t want to use our external relay box.
Long story short you can hook up just about anything you want to those relays.
