Spatial cal failed video
Enjoy the soothing voice of Jim Neeb as the calibration last step fails
as above
Odd- mine worked fine! Thought it might be an inches vs. millimeters thing but looks like you are in inches as well.
Yep it is strange, I’ve run the 20 times over the past few days. I sent Eric a message when I noticed this. I figure this would let him see for himself. What about that tool fork being a little close… Servo power never knew it was there…
tomorrow I will try it with the rod just below the rod in the 4jaw.
Lol :grin:
I was just looking into this rotary thing again and I went to the wizard says chuck Probe diameter .0246. mine is .63 , what’s in yours if you go to the wizard under rotary dual use.
Ok this was the problem, once I put the correct size of the calibration rod it worked as it should
Ahh, this is a side effect of the metric>imperial conversion.
Your fix is good Brian, it will be more robust on our next update.
