Hey Everyone, In preparation for surfacing my first layer of spoil board, I put a offcut 3’ x 4’ on the front part of the bed, held with two bolts (subsurface) and some double sided woodworkers tape. The first pass was around 0.030" thick, (Wasn’t using the double sided tape then) and found that the edges of the MDF was lifting. I got some tap and tried it again, second pass was around .015" found one edge still lifting… Ran another pass at .005" Reinforced with more tape and a clamp (till it go to it)… That MDF lifted like a tacoed on all 4 corners! Is this normal? Anyway, What is the acceptable amount on smoothness on the spoil board? I’m noticing that the closer it gets to the front of the machine, the more “ripples” it leaves. I’m thinking this has to do with the fact that the dust collection hose is apply more torque to the gantry. This is a 5x10 machine with 12" Z axis, and the dust collection hose attaches pretty high up on the Z axis. Close to the center, I don’t think it’s pulling as much… hence it’s a bit more smooth. Please note: I’m a Machinist, not a wood worker, and a bit OCD, so, this may be acceptable. But it wouldn’t be for a machinist in metal. I can attach photos later on if needed.
Thanks, Connor
