After homing my machine. Going into utilities, press two. then enter and this error comes up. No clue on what it is. . And my research it suggests that the G-Code could be something wrong with it. But I’m not running g code yet. So I don’t know where the error is coming from any help would be appreciated. Thank you.
I was getting an error on a job a while back and the G-Code wouldn’t load. My issue was that there were some characters in the G-Code file name that the system didn’t like. I changed the file name eliminated some symbol characters and it worked fine.
Not sure if you have the same issue, but thought I’d mention this in case it helps.
unfortunately I can’t even get to the G code
Attach the g code here, even if you can’t run it when you load it the entire file is checked ahead of time for errors so that may be what it is
Eric thanks for getting back to me.
I have not loaded the G-Code I have homed the machine then go into the utility press 2 then enter and this pops up, I’m un able to load run the setup utilities or upload the g code
this started happening after I turned off the power to the computer by accident
What pops up exactly? can you share some screenshots?
