I’m soliciting feedback on the AirWeights vacuum holding system. Do you have this system and how has it worked out? Tips, tricks, or pictures?
I’m planning my next spoil board setup (v3). I actually have a vacuum table using MDF (homemade but much like a hurricane system). I intend to keep that in some configuration as it is great for full sheets of plywood. However, it isn’t really good for anything else.
These days I am doing a lot more small pieces with two sided operations. Work holding is a big challenge. I also would like repeatability with custom jigs for making small numbers of a product with time in-between.
My ultimate goal is to have a setup that:
- Uses my existing high volume vacuum setup for perfect 5x5 ply and good 4x8 plywood operations for cabinet style projects
- Incorporates T-Tracks and dog holes, though maybe more sparingly than other setups due to the vacuum tables needs
- Uses screw down points for jigs and possibly the AirWeights system
- Vertical table for joinery (dovetail drawers)
- Easier ability to change zones (for example, using my probe to have an exact model of the machine frame now that I truly trust the machine coordinates – thanks to the Ex controller and hard stops!)
Thanks for any feedback
