Thoughts on mounting a machining fixture plate to PRO4896
I’m planning to outfit our machine, which we normally use for 3/4" plywood, to do a little bit of metalwork. And yes… the machine is mounted sideways!
The goal is to have a removable setup that allows us securely do some workholding for aluminum (or more, if possible) milling, without having to adjust the wood routing setup that would exist concurrently (2 pieces of .75" mdf spoil board, with the usual addition of a .75" piece of plywood as the workpiece).
My plan is to mount some removable standoffs through the spoil board, then fix a sub-plate to the standoffs, and then mount a fixture plate to the sub plate and then do what I gotta do
Something like this:
My thoughts are
Either through-bolt the standoffs through the frame or use regular 8020 drop in nuts to secure them.
Use 1/2" steel? 3/4" aluminum for the subplate? The subplate may or may not be resting on the plywood beneath it, or be suspended in free space if there is no wood loaded on the machine during use of this fixture.
I suppose I could mount a pre-drilled fixture plate directly to the standoffs, but from what I can see based on available sizes of commercially made plates, the sizing makes it more sensible to mount a stiff sub-plate first and then bolt my fixture plate to that. I’m not sure if this span of unsupported material will pose a problem, and what thickness of subplate or fixture plate will be needed to assure adequate stiffness for some reasonably enthusiastic machining, or if simply making sure there is a piece of 3/4 ply underneath the sub-plate at all times would make a big difference in and of itself.
I’m wondering if anyone has tried something like this, or has any general advice about fixture plates, sub plates, stiffness, or anything that I would want to know before I just start going at it.
From what I’ve read here, it would make sense to include either or both of an IPA misting system and a vortex cooling system.
I don’t have any help for you unfortunately but I’d love to see a few photos of your sideway machine :grin:
Managed to get this setup going
Link with video
Run with 1/4" single flute 1.25" carbide Micro 100 endmill, no coolant (haven’t got the IPA mist setup yet). 18,000 RPM, 29.93 ft/min feed rate, .1" DOC, .1" WOC.
finish wasn’t so great but I roughed it to 0 stock and then took some finishing passes, so I bet it could be quite improved.
Can we just talk about the machine orientation?!
Yes, let’s talk about it! lol.
It works surprisingly well, minus a few procedural things you have to get used to.
The weight of the gantry X axis (or whatever is traveling up and down in this orientation) is offset by a constant force spring that’s mounted underneath the gantry and routed via pulley up and over the machine.
I can make a longer post with pics of how we did this whole setup (actually have done two machines in similar style).
PLEASE do! :slight_smile:
Your wish is my command, I’ll compile the info about our two builds and make a separate post.
Ya, no kidding. That is a cool way to save a lot of floor space.
Also can see that you could come some ways to really easily load sheet goods into a machine like this.
Well just shut my mouth.
Link to build log for sideways machines here.
