Tracking lines on the outside of spoilboard only
Hey guys, I was having some trouble with some of my finer detailing lately. The lines appear to go shallower towards the center of the project. I thought that it was possible an issue with the spoilboard, so I went ahead and resurfaced the spoilboard.
Once I did that I noticed tramming lines along the outside of the board only. Towards the center of the board, it flattens it, and there are not any lines, but along both of the outsides of the x axis, I’m getting some harsh lines.
For reference, I have a 4x4 machine from when avid
was “CNC Router parts” back in 2016.
My guess is there is something loose on the Z stage.
May want to check that the spoilboard is securely fastened, I put some washers in between the screw and the mdf and got much stronger purchase.
You can also check that there is no irregularity in your axes by putting a long level on each linear rail and checking for gaps with feeler gauges.
Please give us a update on what you have found to be the reason. I put blue Loctite on nearly every bolt except the waste board I know it’s not a guarantee but it might help prevent a shake loose bolt or two…
Well, I’ve got to admit my dumb mistakes on this one. I saw hoofs and thought zebra. After checking every single bolt, adjuster, and measuring every single axis, it all measured pretty spot on.
Turns out, my dust shoe was the issue, and at the edges are where the bristles fell off the edge of the spoilboard and caused issues. Removed the dust shoe, reran it, and everything came out good!
Time to design and build a dust shoe that is independent of the z axis
Also, I will definitely be adding washers, honestly, not adding them in the first place was kind of dumb of me lol
Yay!! :grin::+1: Avid came out with a new one (not sponsored) :wink:
Is it independent of the z?
https://www.avidcnc.com/avid-cnc-universal-dust-shoe-p-1379.html
Why would this cause that issue? Were the bristles pushing on the spoilboard hard enough to affect the cut depth?
Are you going to actuate it or attach it to the plate behind the Z axis?
I guess so, when I measure the lines on the side, they were the same as the dust shoe. I think when the edge of the shoe passed over the side of the table, it cause I little bit of canter on the router.
And the shoe assembly I built is fixed to the plate behind the router now and I’m not having any issues
