Hi guys, I was wondering if there’s a tram plate that can micro ajust the nod as well as the tilt. You know no shims… It wouldn’t be a bad idea to bring it up in the next meeting you have the green light and two thumbs up on this end!!
Thanks Jeff
Thanks Jeff
When I was tramming the nod on my machine, I realized you’d need two of these. One between the Z carriage and the gantry to make sure the motion was vertical, and one between the Z carriage and the spindle to make sure the bit was vertical.
The spindle is already offset from the gantry enough, I wouldn’t want to add a few more inches just to avoid shims.
I drilled and tapped the tramming plate for 4 grub set screws to adjust the nod and the included pic is for adjusting the tilt, one on each side. The tramming blocks can be pivoted out of the way if needed.
Yes if it could be the same size or just a little bit bigger!?
Poppy welcome back!! Do you have a photo? I would be interested in seeing
We’ve actually talked about this a little. The method I have successfully done on a bunch of machines for “nod” is to loosen bolts on the gantry risers, “nod” the spindle as needed and tighten those bolts again. On the 5 or so machines I’ve done this on I’ve had more than enough adjustment to dial things in perfectly. The best part is that you don’t have to mess up the other direction to achieve this.
One of the the nice features with using the tramming blocks, is once set they can be pivoted out of the way and if you need to re-tram , just loosen the bolts on the tramming plate and swing the blocks back in place and retighten the tramming plate bolts.
These are awesome!! I’ll have to look into this further… thank you ![]()
@Eric When using this method, how do you control how much adjustment is made?
I’m not sure Bob I haven’t tried this yet! Maybe Eric can give a few more pointers ![]()
@Eric I forgot to tag you in the last post so you probably didn’t see it. Can you explain how to control the nod using the process you described?
Ah so I have this:
What I did was install this and then loosen the bolts and use this as a guide to see where I was at.
While this is a really nice and easy to use tool, you don’t need it. I grabbed one because at least a few times a year I am setting up a machine so for me it makes sense.
In reality, all you really need is a stick that you can “hang” off of your spindle using a drill rod or something. I’ve made them out of bits of scrap I have around in the past.
Basically, you take some flat stock of something sturdy and drill a hole in one side and pound in a 1/4" drill bit or a drill rod from the hardware store. Do the same on the other and but facing the opposite way (so one up and one down) You can use that to measure the distance away from the spoilboard you are.
Just rotate it one way, measure and then rotate it 180 degrees and measure again. Repeat until it’s equal. It’s a little bit of a caveman approach but it works.
Exhuming an old thread. I came up on a search about nod adjustment. My Standard machine is 13 years old now and getting a rebuild with new parts. This machine did not make provisions for tramming, but I’ve added a mod for a bit of left/right tilt. Would like to add nod adjust as well if possible. When adusting with the mod shown about I can see that the grub screws are set as necessary - but afterward, how do you lock itin place so the setting holds? Best I can figure is to insert shims in any gap and then tighten everything down -correct?
I see there’s locknuts on the gibs is that what you mean?
yeah. I can see that you’d have to loosen the bolts holding the gantry to the upright supports. Then adjust the grub screws in order to get the nod right…then what? Just retighten? I figure you’d need to add shims in whatever gap showed up in order for the nod to hold, then retighten support bolts. If the tramming blocks shown above can be swung out of the way afterwards then they have no purpose once everything is tightened back up.
No those are two different methods you could use one or the other I would just put shims in and call it a day
shims will work and I’ll likely just stick with that for now…still curious as to how the adjustment holds after removing the tramming blocks. Once you retighten all support bolts does the adjustment just “stick”…seems it would drift back to about where it was before.
This is some great information! Working on tramming my machine. Few Questions:
@Poppy - Am I blind or is there not a picture of these “tramming blocks” you referred to? Is it the schematic you posted? It’s so small I can’t make out what it is exactly. I see the grub screws with nuts on them for tramming the spindle “nod”, but I don’t see any tramming blocks. The name got me curious and I can’t find any other post about them.
Your grub screw solutions is awesome though.
@Eric - You said you like to shim the “gantry risers”. Are you referring to putting some shims between the aluminum gantry and the CRP820-02 Gantry Interface plate (see pic) to effectively tilt the whole gantry forwards or backwards?
Any insight would be greatly appreciated. Thanks!
I don’t put shims there. On my many machines I have trammed the most I have had to do is loosen the gantry risers and tip the spindle back and then retighten.
