I just upgraded my Avid 4896 motors with a new EX controller. I followed the instructions for updating my VFD (Mitsubishi D700) but whenever I try to start the spindle I get a 9031 error message. I first attempted sending a file from Fusion and then attempted a spindle warm up.
I’ve checked and rechecked the cables, reset the machine using the e-stop, and turned the machine/centroid on and off more times than I can count. Anyone have any ideas where to look to figure out what’s going wrong?
I looked further into it - super helpful suggestion! I attempted to run the D700 a few times and I got two error messages (e.oht and eoc1). Not sure what could be causing either. The spindle was working perfectly before I swapped out the motors
E.OC1, E.OC2, E.OC3: Overcurrent Trip. Occurs during acceleration (OC1), constant speed (OC2), or deceleration/stop (OC3). Check for short circuits, heavy loads, or insufficient acceleration/deceleration times.
First I would check that I updated the VFD correctly. Then I would check the wires for opens/shorts with an ohm meter. Then I would reset the vfd programming and try again.
