I need an urgent help diagnosing and resolving a current issue with my CNC , it’s been 2 days now and I paused all my work and projects ,please let me know if someone can help walking me through resolving this issue or any suggested work around…
i have a CNC pro 6x10’ servo with ex controller and smart VFD 4H
My Avid CNC (running CNC12) stopped the spindle in the middle of a job while the machine continued jogging normally. Since then, the spindle will not start from CNC12.
Here’s what I’ve verified:
I can hear a click coming from the Ex controller box after sending the command to run the spindle but the spindle doesn’t run.
The spindle runs normally when started directly from the Mitsubishi FR-D720 VFD in PU mode.
The VFD has no fault codes and works correctly.
The VFD is in EXT mode during CNC operation.
M3 S18000 in MDI does not start the spindle.
The VFD receives approximately 5 V on terminals 2 and 5 (analog speed signal).
The VFD RUN LED never turns on
I checked the wires and I didn’t see lose wires anywhere… could this be a relay ??? Can someone help please?
I don’t have that VFD but there is likely a way to configure the VFD so that it starts the spindle without any connection to the AVID control box. I would start with that to shrink the problem space. If you can start it manually you have a crude solution that will let you get some work done. If you are seeing 5v at the VFD it is likely the VFD though there is a direction signal in there as well. I would have thought 18000 rpm would be higher than 5V.
If the VFD can control the spindle “manually” the I would reseat the spindle wires. Then I would just wiggle them around to see if anything changes.
I had a similar problem a couple weeks ago on mine. Turned out to be a bad contactor for the spindle enable. Since i don’t have plasma, i could just move it over to the plasma head enable channel on the contactor.
