ATC Set Up Issues
So I’ve solved the z axis fault debacle and am now setting up the ATC.
Issue 1 - When I tried to do a spindle warmup I get a message stating that the cutter selected is a router and no warmup is needed. I’ve gone back to the Acorn Wizard a few times now and verified that I have “spindle” selected and chose the AV40S as my spindle. I’ve restarted all boxes and even the PC but I keep getting told “router” is selected.
Issue 2 - I went into the ATC utilities to extend and retract the tool rack to ensure it was working, the rack extends okay, but when I try the retract button I hear air being dumped but it doesn’t seem like air is filling the opposite side of the cylinders to push the rack back. I can push it back by hand but it won’t go back on it’s own. I’ve double and triple checked the flow valve direction and opened up the needle valves but nothing seems to help. Could it be a solenoid on in the aux box is not activating to put air on the back side of the cylinders?
I ran through the ATC diagnostics and here is what I’ve found.
  1. Rack retract test - Failed - unplugged hose at the aux box and no air discharge - Sensor test passed after pushing rack back manually
  2. Rack extend test - Good - Sensor test also passed
  3. Tool bin obstruction test - Good
  4. Air pressure test - Good
  5. Air blast test - Failed - unplugged hose at the aux box and no air discharge - Air blast is turned on in the setup and set for 1 second
  6. MTC button test - Good
  7. Spindle stopped test - Good
  8. Drawbar sensors test - Good
It seems there is an issue with the air activating on the rack retract and air blast functions. That along with the system not recognizing the cutter as an AV40S spindle as opposed to a router even though spindle is specified in the Acorn Wizard.
Mine does the same thing.
Make sure the ribbon cable on the air solenoid block is plugged in all the way
Well that was easy!!! Ribbon cable was good at the solenoid block but was a little loose at the board.
All seems well now! Rack retracts and air blast is working now.
I moved forward with the rest of the set up and calibration steps and just loaded my first two tools into the rack. This is so cool!!!
The locating caps made tool bin locating as easy as it can get. I did all 10 in less than 15 minutes. The set up videos were very helpful!
Thanks Eric!!
Does it recognize the AV spindle now?
Seems like it would be a good idea to check them wires before you install the boxes. What I mean is you don’t know how much bouncing around them UPS drivers are doing!!
You’d know right away if it didn’t recognize the smart spindle.
The ribbon cables just control the air solenoids and can come out in shipping, we’ve already addressed and fixed it
You are referring to the first issue?
Both actually
I didn’t see the solution in the thread for the system thinking there is a router instead of a spindle. I have selected spindle in the wizzard also, but it won’t run a spindle warmup because it thinks I have a router. Is the solution an upcoming CNC12 release, or a setting somewhere I missed?
I was saying that we have logged and fixed both issues. New software release is in testing. Ribbon cable fix is being done now
Eric: I’m having the same “router selected as cutting tool”. Ribbon cables are tight. Can you think of any other area I should check before I put in a service ticket?
Ty
That’s not a hardware problem, that’s a software issue. We’ve got a patch for this (and a few other things) coming out next week.
Don’t worry about it for now.
If you do need to warmup your spindle just hit MDI and type in M3S12000 and let it run for a few minutes
I have found that using the pendant you can click “spin - auto/man” off, then click the “spin” button next to it to start the spindle. You can then turn the increment knob to dial up or down the speed for a warm up procedure.
Thanks Eric. You’re Awesome!
Tanks Pertech - that is a great work around - clever!
