I have an avid CNC Pro with the servo system, and I am having a problem with keeping the router bit flat. I flatten a lot of slabs. And what seems to be happening is that the bit comes out of square I may be using the wrong terminology. I am using a 2 1/2-inch bit. However, by the end of one or two slabs, I’m typically off by 3 to 10/100, creating unwanted lines. I make the micro adjustment. Tighten it back up. And the same thing continues to happen. What part of the machine should I examine to correct this issue?
Also, I’m finding ball bearings on one side of the CNC. What would cause this, and when and how should I address this issue?
Are you talking about the bit cutting too deep by the end of the cut, or that the bit is cutting at an angle? If it’s the latter you may need to adjust the tram of your spindle.
