Cam post processors
I just want to be sure but is there any reason why I can’t use both processors, depending if I export toolpaths from Fusion360 or Vectric?
I’m using VCARVE PRO with limited 3D capabilities for the most part but also use Fusion360 for extensive 3D modeling.
Are you asking if you can load G code from Fusion and Vectric? Since those are separate G code files, yes there’s no problem.
Yes, I thought so but wasn’t for sure. Thanks!
