Cnc12 Jogging and overide limits?
Good day.
I finally got my machine moving with Cnc12.
So I am playing around to get used to Cnc12.
A few things I cannot figure out is.
I cannot change the jogging speed from slow to fast it stays on slow.
I restarted it worked when I clicked it …then change again it stays on slow (also is there a way to set the speed…if I can set at a desired speed I do not have to change it anymore…since I can use the pendant.
I cannot jog with the keyboard which would be the preferred method while sitting behind the computer. ALT+J removed the red indication of USB jogging but it does nothing.
How do I override limits like in Mach4…I managed to trigger the Z while playing with the pendant…but how do I overide to move it back?
Is there a way to reverse pendant direction? for me turning right to lower the Z feels more natural than the opposite…which what caused me to trigger the limit lol.
Thanks!
You would use the Control key with the keyboard.
Yes just figured that part out by rewatching the video of first cut. Tnx!
It should change when you click it except if you have your pendant on. When it’s on that takes priority.
Also something that can keep it locked to slow: If your tool height setter is triggered when it shouldn’t be. If it is you’ll get a yellow message in the message box
Hold down CTRL when using the arrow keys. That’s the only way you can jog with the arrow keys
The “Limit Over” button in the upper right. Flipping that will temporarily invert the prox switches so you have a chance to move off of them.
No. A left turn is in the negative direction and a right turn is in the positive direction for all axes.
Got it tnx!
Yahoo Mail: Search, Organize, Conquer
