CNC12 single block mode no spindle turn on?
Hello
question how would I run the single block mode with out turning the spindle on?
I use the single block when I change materials that have previously been drilled and there are no room for mistakes so I make sure it will drill the exact same place but I do not need the spindle to turn on.
Thanks!
Edit your g-code and delete the line that looks like this “S18000 M3”
Have you tried the graph toolpath function to validate the milling position?
Although I might not be understanding your workflow.
That might be an option if the bit in the graph was smaller or a crosshair…if you guys know how to change it let me know.
Tnx!
