Could Someone Give me Advise CAD Software for CNC Projects?
Hello there,
As I am new to this world of CNC machining and excited to dive deeper into creating intricate projects. Although, Right now I am at a crossroads when it comes to choosing the right CAD software for my endeavors.
I have some basic experience with CAD software, primarily in 2D design, but I am keen to expand into 3D modeling for my CNC projects. Precision and accuracy are paramount for me; as I aim to create intricate designs with fine details.
I also value user friendly interfaces and good customer support; as I anticipate encountering some learning curves along the way.
My primary goal is to create designs for CNC machining; including both functional parts and artistic projects. While I am willing to invest in a professional grade CAD software if necessary; I am also open to exploring more affordable or even open source options; as long as they meet my requirements.
After scouring the internet and reading countless reviews; I have narrowed down my options to a few contenders; including Fusion 360; SolidWorks; Rhino; and possibly some others.
I have also gone through this reference post: https://forum.avidcnc.com/t/seeking-recommendations-to-assemble-a-complete-cnc-kit/1405ccsp which definitely helped me out a lot.
Although; I would love to hear from the community about your experiences with these or any other CAD software you recommend for CNC applications.
Thankyou in advance for your help and assistance.
Best CAD Programs for Beginners - General Chat - Avid CNC Community
You didn’t say what CAM software you were using. If it is Fusion it probably makes sense to use the Fusion CAD that is built in. If it is Vectric vCarve or Aspire the CAD is built in as well.
As the linked thread above (and another in that) show, there are lots of options.
I have not tried them all, but I have used F360, and Vectric, and tried Shapr3D and a couple others.
I personally like Vectric Vcarve Pro as my main CAD/CAM for a CNC router and laser if you want to do both machined parts, and artistic things (like 2.5/3D carves). It also supports rotary work.
However, in Vcarve you design in 2D, and then when you create the toolpath, that machining creates the 3D image in the simulator. It can’t create a 3D model.
However, you can load and machine a 3D model.
If you want to create 3D artistic models, I think Aspire is good, but I don’t think its very good for making 3D models of machine parts.
If you want to design everything as a 3D model up front, then I don’t think Vectric products are for you (its just not how they work), so you’d probably want something like F360. I don’t know why, but F360 to me is the opposite of intuitive and takes me forever to design anything, and I haven’t even bothered to try and do CAM with it because the design was so tedious.
For furniture/architecture, I like Sketchup. I haven’t tried importing those into Vectric yet though to see how well the parts import for machining.
Overall, if you can make a good go of F360 and don’t find it as cumbersome as I do, its probably a good choice. Very capable and good price all around.
If you like the Vectric interface, I can say that there isn’t a machined part I couldn’t make with that, with normal 3 axis routing/lasering. When I need a 3D model for the rotary axis, I make it elsewhere and import it.
There are lots of other choices, but they are usually much more expensive if they are integrated CAD/CAM, or much less integrated if they are a lot cheaper. With the cheap ones, you kind of have to build your own process between a few programs.
I mostly concur with all your points. I do very little 3D work and what I have done I have either used the Vectric ClipArt Library or purchased the model from Design&Make. I have made some very minor changes to those models in Aspire but nothing major. Since I don’t have a rotary all my work uses two sided machining so I can’t comment on that aspect.
I frequently use Sketchup to develop multicomponent models, like bookcases, and have found that the Vectric Aspire interface works very well once you get some experience using it. It is a big time saver for 2D machining parts from components defined in Sketchup. I have not tried using Sketchup to create a single component 3D model and export the STL into a Vectric product but I think it can be done and should not be ruled out as a very cost effective possibility.
I have tried using Aspire to create 3D models but have not been able to put enough time in to fully learn how best to use all the tools. I have seen videos where others have mastered that art with great success so I think it can be done, I have no doubt that some other 3D CAD products may be easier to use and I can attest that importing a STL model into Vectric for machining is very straightforward.
The only other 3D CAD software I have tried is Rhino and Fusion but I found both have too steep of a learning curve for my limited need to develop unique 3D models. While I own and use Aspire I could probably easily use vCarve Pro for 99% of what I need.
| jjneeb
June 1 |
I’m glad to hear you say that. I’m going to build a whole set of altar furniture for our new church this fall, and I designed them all in sketchup. To me sketchup is very easy to use for furniture. However, I have yet to import a single piece from sketchup into Vcarve to try and machine it, so I’m glad you say it works well.
