Does anyone have any experience running 2 spindles on the AVID? I don’t know how to wire the 2 together so they can be turned on and off together in Mach. I cannot use a spindle and a router. Thanks in advance.
Hello @one01011
You can try to wire in parallel. Connect the positive point of both spindles to the same power source and the negative point to a common ground. the spindle control signals from both spindles to a single switch.
