EX Controller replacement key for lock
I haven’t been able to find my key. Where can I get a replacement?
Thanks for the help
You can contact support and they can send you one. They are also available on Amazon: PATIKIL Key Shape Socket Spanner Key, 3 Pack Electrical Cabinet Gas Water Meter Switch Key for 0.45"x0.2" Key Shape Panel Lock, Silver - Amazon.com
You can also very easily use a flat head screw driver if you need to get in there.
If you press in on the door as you’re turning it with a flat head it should open very easily.
Wonderful it worked
