Job start problems
My CNC machine was working perfectly fine for a while, probably about two days. However, today, when I tried to start a cutting job, I started getting errors.
When I select tool #7, instead of moving to the tool changer to pick up tool #7, the machine simply moves off to the side until it hits the sensor.
When I try to manually load tool #7 into the spindle using MTC, the machine stops at a random position and displays an error.
I have recalibrated everything I could, but the same problem keeps happening.
Could you please help me figure out what is causing this issue and how to fix it?
The first screenshot shows what happens when I try to start a cutting job.
The second screenshot shows the error I get when I try to manually load the tool using MTC.
Can you show me a screenshot of your tool library in the ATC app?
Also, we did just post a software update today that has a lot of tweaks and fixes in it, it might be wise to update to that.
From the main screen of the CNC12 control software can you go to Utility Menu>Machine>Jog and show me what your travel limits are?
Tnx. Everything is working after the software update
Sweet!
