Mach 4 PWM logic help
Is anyone on here experienced in getting PWM lpgoc to work with Mach4 and an ESS?
I have logic where i am trying to turn outputs true and false based on imouts to control air solenoid relays. I have one version that functions correctly, however it is constantly sending a signal to deactivate my outputs when they are false. This is causing my buffer to fill up and results in lag and FIFO drain errors with my ESS.
I have tried converting to using set-only and reset-only coils, but the reset coils dont actually seem to turn my outputs to false.
