what am I missing here it looks like tools in the rack will not clear the gantry.
Additional pictures would be helpful here. My guess is that it’s 20-40mm too high which could indicate that you’ve got part of it mounted in the wrong channel in the 8020
That looks like an 8" gantry riser to me, so you’d have to be in the lower slot.
I think this is where the confusion comes in:
You can have have “8 inch” or “12 inch” gantry height, and an “8 inch” or “12 inch” Z travel. Those two can be interchanged. So what you likely have is an 8" gantry riser (common) and a 12" Z travel…
This configuration means your gantry isn’t any higher than normal, but that your Z can lift higher and out of the way
Thanks yeah I’m realizing now that I put the linear rail in the top slot and I needed to put it in the bottom thanks again
No problem, we’re already updating the instructions to make it more clear
I did the same thing. I have an 8" gantry and 12" z-axis, I confused the two and installed per the 12" gantry instructions and noticed the conflict. That’s when the “ah hah” moment hit me.
So I guess this means the atc is shipping?
We’ve been shipping hardware. Control boxes/software are following behind soon.
You’ve got the right idea. Wire/hose goes in one channel, hose goes in the other.
thanks for the quick response
Are the instructions available to those who haven’t ordered the ATC yet? I’m interested in ordering one this summer at the same time I want to do some other upgrades, and would be curious to look through the installation steps.
