I have a 4896 with 4HP atc spindle on the way, plus the 45w laser.
I read that I need 220 / 15amp for the spindle.
I can’t find the requirements for the laser. Does it have separate power requirements?
The 45 watt laser system just plugs into a standard 110v outlet.
There’s a switch you can have 110 or 240
Laser Technical Manual Laser Technical Manual
This might be what you are looking for
Its pretty low power, so you can also just get a short splitter cord and run the laser and control box of the same 120V power feed.
