Hey Folks,
I’ve been doing some small scale brass milling with my Pro 2x4 table, and I’ve been tuning the backlash to deal with bore hole circularity, etc.
In the process I noticed that my X axis backlash was quite high (about 10 thou), and looking at the pinons I decided it was time to replace them. I went ahead and replaced the X axis pinon and ended up with about 6 thou backlash. I proceeded to replace the timing belt as well, and after an evening of fiddling, I’ve got the backlash down to about 0.0035". My Y axes are both at about 0.002".
I read here about folks all the time who say that they have backlash at 0.001" or less on a Pro rack and pinon. I’m wondering if I’m maybe doing something wrong in tensioning the belts, or engaging the spring on the rack, but I just can’t get the backlash any lower. I do note that this would appear to be well within specs for the machine, so I’m not too upset, but it would be nice to have the backlash a bit lower.
If nothing else, the backlash means the machine homing can be off by the backlash after homing. Oddly enough I can see the machine home repeatedly to exactly the right spot every single time with dial indicator located at the home position, to less than a thou for sure, but once I have backlash compensation enabled, mach4 appears to randomly decide at times to try take up the backlash and the home position is randomly either correct, or off by the amount of the backlash compensation. At 10thou this was bad enough that I was getting notable problems with double sided alignment of bores. I can reference off a pin on my vice to correct, but it’s a pain that the machine home is not stable when backlash compensation is on. If anyone knows how to keep that somewhat random “adjustment” from happening at the end of the homing cycle I would appreciate that.
Thanks,
Eric
