Hi folks,
Has anyone used these to replace bearings on their Pro?
The universal constant is you get what you pay for with bearings.
The product listed doesn’t state a grade and the cost is very low.
Good point - It might not be the best choice. I’m in Canada and ordering from Avid means tons of shipping and duties - Its often way cheaper to find something thats already on this side of the border. As far as I can see, Avid doesn’t give the specs of those bearings (Just the nominal dimensions). If anyone can recommend something that fits and is decent I’d really appreciate it. ![]()
Okay I have a bearing block out. I believe its a Hiwin HG20. but there’s more to the spec.
I think this is the data sheet. It’s definitely the Square type. Mine measures 24mm high. I’m Guessing HGL-CA? Anyone know well enough to confirm?
Linear_Guideway-(E).pdf (227.9 KB)
