Hello, I have some questions about the rotary axis on my Avid cnc.
I use Vcarve Pro for cad/cam software.
I am looking to turn some table legs like the one I attached. I cannot figure out how to program it (which might be a question for the Vectric forum), but I also realized in the process that I do not know how to set the rotary to different degrees.
Is there a button somewhere or a degree input? I used the buttons to manually rotate it to say 90*,* but I can not get it precisely at 90.000*–*it will go to say 90.002*, and then if i turn the increments down and adjust more, it will bounce back and forth but never quite achieve the true degree. What am I doing wrong?
Any thoughts or experience with such a situation would be appreciated!
thank you
