Sheetcam Gcode export is off table dimensions
Using an AAS 44x148 table with Avid Mach 4 and using Sheetcam version 7.0.21.
When I set my layers in Sheetcam and export as a gcode, and then load it into Mach4, the placement of the job will be outside the parameters of the table (photos attached), and does not match up with the nesting I set in Sheetcam.
The dimensions of the table are consistent between softwares (44x148), so I am not quite sure what to do. And Avid customer support has not been very responsive to calls I have made.
Can you post the exported g code and the sheet cam file here so we can take a look?
Sure, I can do that when I am back in the shop on monday.
