Tool compensation?
Hello…is there something like tool compensation?
If I cut something I would like set that the tool has a smaller diameter…so it can make the item smaller and not to go back in vcarve.
What are the options here?
Tnx!
Tool comp is a feature in CNC12… however for it to work you need to have it on in your G code.
Vectric doesn’t output tool comp codes because it (like most CAM software) does the tool comp “in software”
So you can use the tool comp feature but you’ll be editing or writing your own g code. The feature is well documented in the CNC12 manual on centroids site.
