Tool Height Setter not setting up
When I go through the process of setting up my tool height setter, it asks if the spindle is over the plate. I type y, then press cycle start green bottom, and nothing happens.
Any Ideas?
caps lock on? It needs to be lowercase y
Unfortunately, that didn’t work
Are you positive you had caps lock off? And if you did, try SHIFT+Y to see if that works…
That didn’t work, but I rebooted the computer, and it worked.
Thanks for the help.
No problem!
