Won’t home with crashing. I did the test to check limit switches and homing sensors and in the diagnostic screen with put a wrench on the y2+ the y2 is not lighting up. Look on avid YouTube and it was lighting when they did it. Could that be my problem if so how do I fix that. Newbie here with an avid. Previously had a onefinity
Check those two connections Make sure they’re on all the way just a hand tighten should be good enough
I had the same issue at first. Checked all the limit home connections just like you did. Turned out I had swapped the Y stepper motor and Slaved stepper motor connections.
Thanks!! That was the issue
Awesome!
