325 limit job cancelled
hi i am absolutely new. I just build my pro4896 machine I try to do a gantry square procedure. when I try to use the touch plate but after touch the bottom and the right side it is showing 325 Limit: job cancelled.
The error you’re seeing shows the machine trying to move outside it’s travel limit in X.
Are you able to jog by hand in X to the extents of the machine?
yes i do
What is it you’re trying to use your touch plate on? Can you show us a picture?
If you’re trying to find the corner of your spoilboard I wonder if your touch plate is right on the edge of where the machine can reach?
Are you able to freely jog to the left far past the touch plate?
no i can not
now it is hitting the touch plate side hard
If you can’t jog your machine all the way to the left of the touch plate (based on your picture) then there’s something not setup right with your machine. Please open up a support ticket and someone will help you troubleshoot:
Use the “support” link at the top of this page.
somehow the touch plate settings was changed
actually I can jog it
I did moved the wood from the end of the machine but the problem is same job canceled. when the bit touch the side it is moving a bit even if I hold it
I’d open a support ticket so someone can help troubleshoot
I did thank you
The support was amazing they solved the problem. That was my mistake of course. First I setup the machine for mm but then I changed my mind and changed the settings to inch. Only problem was even if the program showed in inch the machine tried to work with mm.
Anyway thank you for trying to help me.
