907. Message: x axis travel exceeded
So I’m flattening a slab and am about 80 % through it. It just stops and give me and
907 x axis travel exceeded line 78
After researching it, this is what I found on line NNNNN.
Cause: Software travel limit would be exceeded by the requested move.
Effect: Job canceled.
Removed: Start of new job
The spindle is over a foot from the True X axis limit.
Has anyone experienced this? If so, how do you fix it?
Line 78 is in BOLD text
The software is looking ahead and would go to x -.250 but it would be outside your machine’s limits, so it stops. How far left can you jog the x-axis? Make sure your program doesn’t go past that area. There are various ways to do this, depending on what you use (Fusion / VCarve, etc)
I’m a foot away from the edge. I’m using v carve pro; how do I make sure that the program doesn’t go past that area?
It’s look ahead. Yes, your DRO is showing it at 18" from the edge at that moment. When you jog all the way to your X minus limit what does the DRO show? You’d need to know that first.
Corbin How do I find a DRO tutorial ? so I can learn what it is and how to use it and monitor what is going on?
Check this video out:
Sounds like you might have an XY offset set incorrectly
