I was wondering if there is anything should consider with the laser module. Already planning the air compressor and the Vetric laser add on. But not sure if there is anything else should consider. Do I need any specific fittings/hoses might be needed? Fume extractor maybe. any help/idea/guidance is appreciated!
I’d check through the laser category here. There are folks that have made some fume extraction setups, some honeycomb base panels for through cuts, etc.
I’d also strongly recommend some kind of exhaust or fume extraction, especially if you’re cutting plastics or coated materials, since the smoke can build up quickly
I am looking for a hood design for the 45w laser, are you aware of any?
