I have screwed up the top view of the graph view. I cannot figure out how to reset it so that you can see the entire sheet instead of the side. (Sorry for the dust)
Bob
Looks like the actual issue is that your g code is posted wrong… unless you meant to cut a giant line like that.. Did you happen to use the Mach post by accident?
Post your g code here:
www.g54.app and share a link back so I can check it out
Toolholder Ramps Narrow.txt (4.5 KB)
Looks like you used the Mach post instead of the EX post. That’s your issue
