I have been having a lot of trouble setting up a drag knife. I used the gadgets and put in .25 offset but it cuts inside corners or jagged curves. I have searched and even used AI and i cant figure it out. Ii use Vcarve pro, any help is appreciated!
Those toolpaths you show on screen look like they should work…
If you’re using the dragknife gadget in Vectric the “offset” is the disance that the blade is behind the centerline of the spindle.
Did you see this video: https://youtu.be/hJhMaqDDmFM
