Lower z speed a bit when homing
Hello..
How do I lower the speed a bit on the plasma when pressing home…
It often trigger the z sensor….I do not get this on the router.
2 more things…
It seems when I am in the graph menu the point/does not move when I move the machine…but when I do a dry run it works good….
When you press reset it looses position and need to home again…again the router does not seem to loose position quickly..
So when the torch crash I cannot resume without re home the machine …
I am still on the old plasma version cnc12…since when I use the newer one it has a problem with the torch
Ohmic/ float switch.
Tnx!
You can’t, this is a preset number
This can happen from time to time on that version of plasma you’re on. We’re working on an update to address that but it likely will be several months before it’s out.
This is the way it works on that version of plasma. If you want to start at a particular place you can use the restart mode and pick where it starts.
This is the correct behavior for the reset button. If you’re just trying to stop the machine press Cycle Stop and not the reset button.
This isn’t necessarily true (depending on the crash) if you avoid pressing the reset button you can usually clear the fault (fix the torch, jog above the material) and proceed on
That newer version is beta version, don’t use that one.
