The laser will test fire from adapter pro.But when I start a program it will not start.
Could someone give me some direction to fix my problem. Thanks
Are you using the EX controller?
No, I am using Mach 4 with smoothstepper.
Checkout my laser setup guide here: Mach4_ESS - Google Drive
I also have post processors for Vectric and Mach4 in that same directory, as well as some screensets that add some laser features.
Thanks jim and jeff, i appreciate the help and your response.
Hey Jim, I am still unable to get the laser to fire from mach 4. It will test fire from the adapter pro. I have checked all the wiring and everything is tight. I have checked the config pins and everything seems to be in order. I have set it up using your post. I am at wits end if you can help I would greatly appreciate it.
Send me an email at jnwdwks@gmail.com. I’ll have a bunch of questions for you and its easier to do the communication over email.
