I’m on step 1.1.7 and trying to mount the table axis crossmembers on the lowest level since I have a vacuum table. In one of the holes there is a screw coming from something inside of the table axis and blocking the screw from the cross member from fully seating.
The uppermost mounting hole has the same issue, the only possible way of mounting the Crossmember without collision with another screw from inside the table axis is to mount in the middle position.
Is this screw from inside supposed to do this? Is it okay to just force it. Or do I need to open up the dust cover on the table axis and fix something?
This column of tapped holes, the top hole and bottom hole, has a screw protruding into the taped hole from the rail screw inside the table axis. It protrudes so far that the hole cant be used to mount the crossmembers.
