After homing the machine, I jog X, Y, and Z to near the corner of my 19mm thick MDF part. I then position the TP on the corner of the part and connect the magnet to the 12.7mm end mill. At this point, I like to pick up the TP and touch it to the bit to confirm the indicator shows Active - it does. I then select the upper left corner icon in the probe routine.
Normally, the Z moves slowly closer to the TP until it makes contact then backs off. But now it moves much too fast and crashes into the TP and I am at a loss to understand why. I cycled power on everything and tried again with the same results - I hit the EStop button before it hit the TP.
The machine ran fine just before this, but I did make one change: I switched the machine to metric units from inches. I suspect this is somehow at the root of the problem, but all the machine settings appear to be correct.
Here’s a screen shot of the current settings (I have never changed these)
I’m thinking my next step should be to reload the machine profile(?)
