Making some plaques for friends. Usually do that out of Maple, since it carves nicely and is tight grained enough to not “fuzz”. However, maple where I live is much more expensive. Do you know of a lower cost wood that fits well with CNC router machining? I’ve tried poplar, but it tends to fuzz up and requires a LOT of sanding. I’d be quite interested in your experience.
I use the harder woods. Maple, Cherry, Walnut, Iron wood, Ebony, Padouk, Yellow heart. The only time I see fuzzies is when I use a flat end or v bit. The tapered ball nose bits do a much better job at reducing the fuzzies, that and a really small step size. Another option is to stabilize the wood. Stabilized wood provides depth that is not available with other materials.
Just find whatever hardwood is available in your area that is affordable, and be sure to go to a hardwood dealer and not a big box store. For me, on the west coast in California, cherry is cheaper than maple. Poplar is still a soft wood.
Has your hardwood gone up like crazy this last year? Here in Arizona there is little thats under $10/bdft. Its getting to be that the wood is worse than buying new tools.
Not too much…S2S cherry was $4.27 a bf a few weeks ago. It’s usually around $5 or under. Walnut is $8-$10’ish.
Those are great prices.
If you haven’t already, try Timber Hardwoods in Mesa. I generally have better luck there over Woodworkers Source.
One trick is to make a commercial account with the hardwood dealer! It can help give you better rates.
Ya, Timber is my main place. However, Walnut was $14, Sapele is now $12, I think maple/cherrry were $8-9.
Woodworker’s source is only for when you are desperate for something quick ![]()
If I need a lot, I actually go to Spellman’s in Phoenix. Its a long drive, but they have much better prices (thats where Timber gets a lot of their wood), and its all a lot “fresher” so flat and straight.
